Title | Size | Downloads |
12-Acronyms-book.pdf | 133.33 KB |
H3C network technology acronyms
# A B C D E F G H I K L M N O P Q R S T U V W X Z
Triple Data Encryption Standard |
6PE |
IPv6 Provider Edge |
A |
AAA |
Authentication, Authorization and Accounting |
AAL |
ATM Adaptation Layer |
AAL5 |
ATM Adaptation Layer 5 |
ABR |
Area Border Router |
AC |
Attachment Circuit |
AC |
Access Category |
AC |
Access Controller |
ACA |
Acquire Change Authorization |
ACCM |
Async-Control-Character-Map |
ACFC |
Address-and-Control-Field-Compression |
ACFP |
Application Control Forwarding Protocol |
ACL |
Access Control List |
ACS |
Auto-Configuration Server |
ACSEI |
ACFP Client and Server Exchange Information |
AD |
Active Directory |
ADM |
ATM Direct Mapping |
ADPCM |
Adaptive Differential Pulse Code Modulation |
ADSL |
Asymmetric Digital Subscriber Line |
AES |
Advanced Encryption Standard |
AF |
Assured Forwarding |
AFI |
Authority and Format Identifier |
AFI |
Address Family Identifier |
AFT |
Address Family Translation |
AFTR |
Address Family Transition Router |
AH |
Authentication Header |
AIFSN |
Arbitration Inter Frame Spacing Number |
AIS |
Alarm Indication Signal |
AIW |
APPN Implementers Workshop |
ALG |
Application Level Gateway |
AM |
Analog Modem |
AMB |
Active Main Board |
AMD |
Answering Machine Detection |
AMI |
Alternate Mark Inversion |
A-MPDU |
Aggregated MAC Protocol Data Unit |
ANI |
Adaptive Noise Immunity |
ANSI |
American National Standard Institute |
AP |
Access Point |
APD |
Avalanche Photo Diode |
APP |
Application Protocol |
APPN |
Advanced Peer-to-Peer Networking |
ARP |
Address Resolution Protocol |
ARQ |
Automatic Repeat Request |
AS |
Autonomous System |
ASBR |
Autonomous System Boundary Router |
ASM |
Any-Source Multicast |
ASPF |
Application Specific Packet Filter |
ASPF |
Advanced Stateful Packet Filter |
AT |
AppleTalk |
ATD |
Attribute Discovery |
ATM |
Asynchronous Transfer Mode |
ATM |
Auto Teller Machine |
AU |
Administration Unit |
AUG |
Administrative Unit Group |
AUG |
Administration Unit Group |
AU-PTR |
Administration Unit Pointer |
AVF |
Active Virtual Forwarder |
AVF |
Appointed VLAN-x Forwarder |
AVP |
Attribute Value Pair |
B4 |
Basic Bridging BroadBand |
B8ZS |
Bipolar 8-zero substitution |
BAS |
Broadband Access Server |
BB_Credit |
Buffer-to-Buffer Credit |
BC |
Bandwidth Constraint |
BC |
Boundary Clock |
BCB |
Backbone Core Bridge |
BDI |
Backward Defect Indication |
BDR |
Backup Designated Router |
BE |
Best Effort |
BEB |
Backbone Edge Bridge |
BECN |
Backward Explicit Congestion Notification |
BERT |
Bit Error Rate Test |
BFD |
Bidirectional Forwarding Detection |
BGP |
Border Gateway Protocol |
BID |
Bundle Identifier |
BIDIR-PIM |
Bidirectional Protocol Independent Multicast |
BIMS |
Branch Intelligent Management System |
BIP |
Bit-Interleaved Parity |
B-MAC |
Backbone MAC |
BMC |
Best Master Clock |
BOOTP |
Bootstrap Protocol |
BOP |
Bit-Oriented protocol |
BPDU |
Bridge Protocol Data Unit |
bps |
bits per second |
BQ |
Bandwidth Queuing |
BRI |
Basic Rate Interface |
BSB |
Blockade State Block |
BSM |
Bootstrap Message |
BSMF |
Bootstrap Message Fragment |
BSR |
Bootstrap Router |
BSS |
Basic Service Set |
BSV |
BRI S/T Voice |
BT |
BitTorrent |
B-VLAN |
Backbone VLAN |
C/S |
Client/Server |
CA |
Certificate Authority |
CAC |
Connect Admission Control |
CAMS |
Comprehensive Access Management Server |
CAPWAP |
Controlling and Provisioning of Wireless Access Point |
CAR |
Committed Access Rate |
CB |
Customer Bridge |
CBC |
Cipher Block Chaining |
CBQ |
Class Based Queuing |
CBR |
Constant Bit Rate |
CBS |
Committed Burst Size |
C-BSR |
Candidate-BSR |
CBT |
Core-Based Tree |
CBWFQ |
Class Based Weighted Fair Queuing |
CC |
Call Control |
CC |
Control Channel |
CC |
Continuity Check |
CCC |
Circuit Cross Connect |
CCITT |
Consultative Committee for International Telegraph and Telephone |
CCM |
Continuity Check Message |
CCMP |
CTR with CBC-MAC Protocol |
C-DCC |
Circular DCC |
CDCP |
S-Channel Discovery and Configuration Protocol |
CDP |
Cisco Discovery Protocol |
CDR |
Call Detail Records |
CDV |
Cell Delay Variation |
CE |
Customer Edge |
CEE |
Converged Enhanced Ethernet |
CEM |
Circuit Emulation |
CEM Class |
Circuit Emulation Class |
CESOPSN |
Circuit Emulation Services over PSN |
CF |
Compact Flash |
CFB |
Call Forwarding–Busy |
CFD |
Connectivity Fault Detection |
CFI |
Canonical Format Indicator |
CFM |
Connectivity Fault Management |
CFU |
Call Forwarding–Unconditional |
CHAP |
Challenge Handshake Authentication Protocol |
CID |
Calling Identity Delivery |
CIDR |
Classless Inter-Domain Routing |
CIR |
Committed Information Rate |
CIR ALLOW |
Committed Information Rate ALLOW |
CIST |
Common and Internal Spanning Tree |
CLI |
Calling Line Identification |
CLI |
Command Line Interface |
CLNP |
Connection-Less Network Protocol |
CLP |
Cell Loss Priority |
CLV |
Code-Length-Value |
CMC |
Call Management Center |
CN |
Common Name |
CNG |
Comfortable Noise Generation |
CO |
Central Office |
COPS |
Common Open Policy Service |
CoS |
Class of Service |
CPE |
Customer Premises Equipment |
CPOS |
Channelized POS |
CPS |
Certification Practice Statement |
CPTone |
Call Progress Tone |
CQ |
Custom Queuing |
CR |
Constraint-based Routing |
CRBT |
Caller Ring Back Tone |
CRC |
Cyclic Redundancy Code |
CRC |
Cyclic Redundancy Check |
CRC4 |
Cyclic Redundancy Check 4 |
CRL |
Certificate Revocation List |
CRLDP |
Constraint-based Routed Label Distribution Protocol |
CRLSP |
Constraint-based Routed Label Switched Paths |
C-RP |
Candidate-RP |
CS |
Class Selector |
CS-ACELP |
Conjugate-Structure Algebraic-Code-Excited Linear-Prediction |
CSMA/CD |
Carrier Sense Multiple Access/Collision Detect |
CSNP |
Complete SNP |
CSNP |
Complete Sequence Number PDU |
CSPF |
Constraint-based Shortest Path First |
CST |
Common Spanning Tree |
CSU |
Channel Service Unit |
CT |
Class Type |
CTR |
Counter mode |
CUG |
Closed User Group |
CV |
Connectivity Verification |
CVLAN |
Customer VLAN |
CWMP |
CPE WAN Management Protocol |
DAC |
Digital to Analog Converter |
DAD |
Duplicate Address Detection |
DAR |
Deeper Application Recognition |
DCBX |
Data Center Bridging Exchange Protocol |
DCC |
Dial Control Center |
DCD |
Data Carrier Detection |
DCE |
Data Circuit-terminating Equipment |
DCE |
Data Center Ethernet |
DCF |
Distributed Coordination Function |
DD |
Database Description |
DDN |
Digital Data Network |
DDNS |
Dynamic Domain Name System |
DDoS |
Distributed Denial of Service |
DDR |
Dial-on-Demand Routing |
DE |
Discard Eligibility |
DED |
Designated Edge Device |
DER |
Distinguished Encoding Rules |
DES |
DF |
Designated Forwarder |
DFS |
Dynamic Frequency Selection |
DH |
Diffie-Hellman |
DHCP |
Dynamic Host Configuration Protocol |
DHCPv6 |
Dynamic Host Configuration Protocol for IPv6 |
DID |
Direct Inward Dialing |
DID |
Device ID |
DiffServ |
Differentiated Service |
DIS |
Designated IS |
DLCI |
Data Link Connection Identifier |
DLDP |
Device Link Detection Protocol |
DLSw |
Data Link Switching |
DM |
Delay Measurement |
DM |
Diagnostic and Monitoring |
DMC |
Device Management Controller |
DMM |
Delay Measurement Message |
DMR |
Delay Measurement Reply |
DMZ |
Demilitarized Zone |
DN |
Distinguished Name |
DNAT |
Destination Network Address Translation |
DNAT |
Destination NAT |
DND |
Do Not Disturb |
DNS |
DoD |
Downstream On Demand |
DO-EO |
Delayed Offer to Early Offer |
DoS |
Denial of Service |
DPD |
Dead Peer Detection |
DR |
Designated Router |
DRB |
Designated Routing Bridge |
DS |
Differentiated Services |
DSA |
Digital Signature Algorithm |
DSCP |
Differentiated Services Code Point |
DSL |
DS-Lite |
Dual Stack Lite |
DSP |
Domain Specific Part |
DS-TE |
DiffServ-aware TE |
DSU |
Data Service Unit |
DTE |
Data Terminal Equipment |
DTIM |
Delivery Traffic Indication Message |
DTMF |
Dual Tone Multi-Frequency |
DU |
Downstream Unsolicited |
DUID |
DHCP Unique Identifier |
DUID-LL |
DUID Based on Link-layer Address |
D-V |
Distance Vector |
DVMRP |
Distance Vector Multicast Routing Protocol |
DVPN |
Dynamic Virtual Private Network |
DWDM |
Dense Wavelength Division Multiplexing |
E2ETC |
End-to-End Transparent Clock |
EAA |
Embedded Automation Architecture |
EACL |
Enhanced ACL |
EAD |
Endpoint Admission Defense |
EAIS |
Ethernet Alarm Indication Signal |
EAN |
Ethernet Access Node |
EAP |
Extensible Authentication Protocol |
EAPOL |
Extensible Authentication Protocol over LAN |
EAPOR |
EAP over RADIUS |
EAP-TLS |
EAP-Transport Layer Security |
EAP-TLS |
Extensible Authentication Protocol -Transport Layer Security |
EBS |
Excess Burst Size |
EC |
Echo cancellation |
ECDSA |
Elliptic Curve Digital Signature Algorithm |
ECM |
Error Correction Mode |
ECMP |
Equal-Cost Multipath |
ECN |
ECP |
Edge Control Protocol |
E-CPOS |
Enhanced CPOS |
ECT |
Equal Cost Tree |
ECWmax |
Exponent form of CWmax |
ECWmin |
Exponent form of CWmin |
ED |
Edge Device |
EDCA |
Enhanced Distributed Channel Access |
EF |
Expedited Forwarding |
EFM |
Ethernet First Mile |
EGP |
Exterior Gateway Protocol |
EM |
Event Monitor |
ENDC |
EVI Neighbor Discovery Client |
End-Of-RIB |
End of Routing-Information-Base |
ENDP |
EVI Neighbor Discovery Protocol |
ENDS |
EVI Neighbor Discovery Server |
ENUM |
Telephone Number Mapping |
EoA |
Ethernet over ATM |
EOAM |
Ethernet Operation, Administration and Maintenance |
EoPW |
Ethernet over Pseudo Wire |
ER |
Explicit Route |
ER |
Edge Relay |
ERT |
Export Route-target |
ES |
End System |
ESF |
Extended Super Frame |
ESN |
Extended Sequence Number |
ESP |
Encapsulating Security Payload |
ESS |
Exchange Switch Support |
ETS |
Enhanced Transmission Selection |
ETSI |
European Telecommunications Standards Institute |
EUI |
Extended Unique Identifier |
EUI-64 |
64-bit Extended Unique Identifier |
EVB |
Edge Virtual Bridging |
EVFP |
Exchange Virtual Fabrics Parameter |
EVI |
Ethernet Virtualization Interconnect |
FA |
Foreign-AC |
FAS |
Frame Alignment Signal |
FC |
Fibre Channel |
FCF |
FCoE Forwarder |
FCM |
Fast Connect Modem |
FCoE |
Fibre Channel over Ethernet |
FCS |
Frame Check Sequence |
FDB |
Forwarding Database |
FDL |
Facilities Data Link |
FE |
Fast Ethernet |
FEAC |
Far End and Control Signal |
FEC |
Forwarding Equivalence Class |
FECN |
Forward Explicit Congestion Notification |
FEP |
Front End Processor |
FF |
Fixed-Filter |
FFD |
Fast Failure Detection |
FIB |
Forwarding Information Base |
FIFO |
First In First Out |
FIP |
FCoE Initialization Protocol |
FIP Snooping |
FCoE Initialization Protocol Snooping |
FIPS |
Federal Information Processing Standards |
FLOGI |
Fabric Login |
FNG |
Fault Notification Generator |
FoIP |
Fax over IP |
FPMA |
Fabric Provided MAC Address |
FQ |
Fair Queuing |
FQDN |
Fully Qualified Domain Name |
FR |
Frame Relay |
FRR |
Fast Reroute |
FRTP |
Frame Relay Traffic Policing |
FRTS |
Frame Relay Traffic Shaping |
FRU |
Field Replaceable Unit |
FS |
Forced Switch |
FSC |
Frame Synchronization Control |
FSK |
Frequency Shift Keying |
FSPF |
Fabric Shortest Path First |
FT |
Fault Tolerance |
FTN |
FEC to NHLFE map |
FTP |
File Transfer Protocol |
FXO |
Foreign Exchange Office |
FXS |
Foreign Exchange Station |
G.SHDSL |
Single-pair High-speed DSL Defined in ITU-T Standard G.991.2 |
GARP |
Generic Attribute Registration Protocol |
GE |
Gigabit Ethernet |
GI |
Guard Interval |
GK |
GateKeeper |
GM |
Grandmaster Clock |
GNS |
Get Nearest Server |
GPS |
Global Positioning System |
GR |
Graceful Restart |
GRE |
Generic Routing Encapsulation |
GTC |
Generic Token Card |
GTK |
Group Temporal Key |
GTP |
GPRS Tunneling Protocol |
GTP-U |
GPRS Tunneling Protocol User |
GTP-V0 |
GPRS Tunneling Protocol V0 |
GTS |
Generic Traffic Shaping |
GTSM |
Generalized TTL Security Mechanism |
GVRP |
GARP VLAN Registration Protocol |
GW |
Gateway |
HA |
Home-AC |
HABP |
HW Bypass Protocol |
HBA |
Host Bus Adapter |
HDB3 |
High-density bipolar 3 |
HDLC |
High-level Data Link Control |
HDSL |
High-bit-rate Digital Subscriber Line |
HGMP |
HW Group Management Protocol |
HGMPv2 |
HW Group Management Protocol version 2 |
HLC |
Higher Layer Compatibility |
HMAC |
Hash-based Message Authentication Code |
HO-DSP |
High Order Part of DSP |
HoPE |
Hierarchy of PE |
HoVPN |
Hierarchy of VPN |
HQoS |
Hierarchical Quality of Service |
HTTP |
Hypertext Transfer Protocol |
HTTPS |
Hypertext Transfer Protocol Secure |
HTTPS |
HTTP Security |
H-VPLS |
Hierarchical VPLS |
HWTACACS |
HW Terminal Access Controller Access Control System |
IA |
Identity Association |
IACTP |
Inter Access Controller Tunneling Protocol |
IAD |
Integrated Access Device |
IANA |
Internet Assigned Numbers Authority |
IBGP |
Internal BGP |
IBGP |
Internal Border Gateway Protocol |
ICMP |
Internet Control Message Protocol |
ICMPv4 |
Internet Control Message Protocol version 4 |
ICMPv6 |
Internet Control Message Protocol for IPv6 |
ICP |
IMA Control Protocol |
ICPIF |
Calculated Planning Impairment Factor |
I-DEI |
Backbone Service Instance Drop Eligibility Indicator |
IDI |
Initial Domain Identifier |
IDN |
Integrated Digital Network |
IDP |
Initial Domain Part |
IDS |
Intrusion Detection System |
IE |
Information Element |
IEEE |
Institute of Electrical and Electronics Engineers |
IETF |
Internet Engineering Task Force |
IGMP |
Internet Group Management Protocol |
IGMP Snooping |
Internet Group Management Protocol Snooping |
IGP |
Interior Gateway Protocol |
IIH |
IS-to-IS hello |
IIS |
Internet Information Services |
IKE |
Internet Key Exchange |
IKEv2 |
Internet Key Exchange version 2 |
ILM |
Incoming Label Map |
ILS |
Internet Locator Service |
IM |
Instant Messaging |
IMA |
Inverse Multiplexing for ATM |
iMC |
Intelligent Management Center |
IME |
Input Method Editor |
IMSI |
International Mobile Subscriber Identification Number |
InARP |
Inverse Address Resolution Protocol |
IntServ |
Integrated Service |
IP |
Internet protocol |
IPC |
Inter-process Communication |
I-PCP |
Backbone Service Instance Priority Code Point |
IPE |
Image Package Envelope |
IPHC |
IP Header Compression |
IPng |
IP Next Generation |
IPoA |
IP Over ATM |
IPoEoA |
IP Over Ethernet Over ATM |
IPS |
Intrusion Prevention System |
IPsec |
IP Security |
IPTA |
IP Terminal Access |
IPv4 |
Internet Protocol version 4 |
IPv6 |
Internet Protocol version 6 |
IPv6 MBGP |
IPv6 Multicast BGP |
IPv6 PIM |
Protocol Independent Multicast for IPv6 |
IPX |
Internetwork Packet Exchange |
IRDP |
ICMP Router Discovery Protocol |
IRF |
Intelligent Resilient Framework |
IS |
Intermediate System |
ISAKMP |
Internet Security Association and Key Management Protocol |
ISATAP |
Intra-Site Automatic Tunnel Addressing Protocol |
ISDN |
Integrated Services Digital Network |
I-SID |
Backbone Service Instance Identifier |
IS-IS |
Intermediate System-to-Intermediate System |
ISO |
International Organization for Standardization |
ISP |
Internet Service Provider |
ISPF |
Incremental Shortest Path First |
ISSU |
In-Service Software Upgrade |
IST |
ITSP |
Internet Telephone Service Provider |
ITU-T |
International Telecommunication Union Telecommunication |
IV |
Initialization Vector |
IVR |
Interactive Voice Response |
KA |
Keep-alive |
L2F |
Layer 2 Forwarding |
L2TP |
Layer 2 Tunneling Protocol |
L2VPN |
Layer 2 Virtual Private Network |
L3VPN |
Layer 3 Virtual Private Network |
LAC |
L2TP Access Concentrator |
LAC |
Location Area Code |
LACP |
Link Aggregation Control Protocol |
LACPDU |
Link Aggregation Control Protocol Data Unit |
LAN |
Local Area Network |
LAPB |
Link Access Procedure, Balanced |
LB |
Label Base |
LB |
Load Balance |
LBM |
Loopback Message |
LBR |
Loopback Reply |
LC |
Logic Channel |
LCFO |
Loop Current Feed Open |
LCI |
Logic Channel Identifier |
LCP |
Link Control Protocol |
LDAP |
Lightweight Directory Access Protocol |
LDP |
LDP ID |
LDP Identifier |
LER |
Label Edge Router |
LFA |
Loss of Frame Align |
LFI |
Link Fragmentation and Interleaving |
LFIB |
Label Forwarding Information Base |
LGS |
Loop-start & Ground-start Signaling |
LI |
Leap Indicator |
LID |
Link Identification |
LLB |
Line Loopback |
LLC |
Logical Link Control |
LLC |
Lower Layer Compatibility |
LLC |
Link Local Signaling |
LLC2 |
Logical Link Control Type 2 |
LLDP |
Link Layer Discovery Protocol |
LLDPDU |
Link Layer Discovery Protocol Data Unit |
LLDP-MED |
Link Layer Discovery Protocol Media Endpoint Discovery |
LLQ |
Low Latency Queuing |
LM |
Loss Measurement |
LMI |
Local Management Interface |
LMM |
Loss Measurement Message |
LMR |
Loss Measurement Reply |
LNS |
L2TP Network Server |
LO |
Label-block Offset |
LOCV |
Loss of Connectivity Verification defect |
LOS |
Loss of Signal |
LPU |
Line Processing Unit |
LQC |
Link Quality Control |
LQR |
Link Quality Reports |
LR |
Label Range |
LR |
Line Rate |
LSA |
Link State Acknowledgment |
LSA |
Link State Advertisement |
LSAck |
LSDB |
Link State DataBase |
LSP |
Label Switched Path |
LSP |
Link State Packet |
LSP |
Link State PDU |
LSPDU |
Link State Protocol Data Unit |
LSR |
Label Switching Router |
LSR |
Link State Record |
LSR |
Link State Request |
LSU |
Link State Update |
LT |
Linktrace |
LTM |
Linktrace Message |
LTR |
Linktrace Reply |
LVF |
Listening Virtual Forwarder |
M flag |
Managed Address Configuration Flag |
MA |
Maintenance Association |
MAC |
MAC |
Media Access Control |
MAD |
Multi-Active Detection |
MAM |
Maximum Allocation Model |
MAN |
Metropolitan Area Network |
MAP |
Mesh Access Point |
MaxBC |
Maximum Number of Bandwidth Constraints |
MBGP |
Multicast BGP |
MBS |
Maximum Burst Size |
MCC |
Mobile Country Code |
MCE |
Multi-VPN-instance Customer Edge |
MCS |
Modulation and Coding Scheme |
MCU |
Multipoint Control Unit |
MD |
Maintenance Domain |
MD |
Multicast Domain |
MD5 |
Message-Digest 5 |
MDC |
Multitenant Devices Context |
MDI |
Medium Dependent Interface |
MDL |
Maintenance Data Link |
MDMF |
Multiple Data Message Format |
MDT |
Multicast Distribution Tree |
MED |
Multi-Exit Discriminator |
MEP |
Maintenance association End Point |
MFAS |
Multiframe FAS |
MFC |
Multi-Frequency Compelled |
MFF |
MAC-Forced Forwarding |
MFR |
Multilink Frame Relay |
MGCP |
Media Gateway Control Protocol |
MIB |
Management Information Base |
MIC |
Message Integrity Check |
MIP |
Maintenance association Intermediate Point |
MKD |
Mesh Key Distributor |
MLD |
Multicast Listener Discovery Protocol |
MLD Snooping |
Multicast Listener Discovery Snooping |
MLSP |
Mobile Link Switch Protocol |
MNC |
Mobile Network Code |
MoH |
Music on Hold |
MOS |
Mean Opinion Scores |
MOTD |
Message of The Day |
MP |
Merge Point |
MP |
Maintenance Point |
MP_REACH_NLRI |
Multiprotocol Reachable NLRI |
MP_UNREACH_NLRI |
Multiprotocol Unreachable NLRI |
MP-BGP |
Multiprotocol Border Gateway Protocol |
MPDU |
MPE |
Middle-level PE |
MPLS |
Multiprotocol Label Switching |
MPLS TE |
Multiprotocol Label Switching Traffic Engineering |
MPLS-TP |
MPLS Transport Profile |
MPoFR |
Multilink PPP Over Frame Relay |
MPP |
Mesh Portal Point |
MPU |
Main Processing Unit |
MQC |
Modular QoS Configuration |
MQC |
Modular QoS Command |
MR |
Mobile Radio |
MR |
Merge Request |
MRM |
Mesh Routing Management |
MRP |
Multiple Registration Protocol |
MRPDU |
MRP Protocol Data Unit |
MRRA |
Merge Request Resource Allocation |
MRU |
Maximum Receive Unit |
MS |
Manual Switch |
MSCHAP |
Microsoft Challenge Handshake Authentication Protocol |
MSDP |
Multicast Source Discovery Protocol |
MSDU |
MAC Service Data Unit |
MSK |
Multicast Session Key |
MSOH |
Multiplex Section Overhead |
MSS |
Maximum Segment Size |
MST |
Multiple Spanning Tree |
MSTI |
Multiple Spanning Tree Instance |
MSTP |
Multiple Spanning Tree Protocol |
MT |
Multicast Tunnel |
MTR |
Multi-Topology Routing |
MTU |
Maximum Transmission Unit |
MTU-s |
Multi-Tenant Unit switch |
MU |
Mobile Unit |
MVRP |
Multiple VLAN Registration Protocol |
MWI |
Message Waiting Indication |
NA |
Neighbor Advertisement |
NAPT |
Network Address Port Translation |
NAPT-PT |
Network Address Port Translation-Protocol Translation |
NAS |
Network Access Server |
NAT |
NAT-PT |
Network Address Translation-Protocol Translation |
NBMA |
Non-Broadcast Multi-Access |
NBT |
NetBIOS over TCP/IP |
NCP |
Network Control Protocol |
ND |
Neighbor Discovery |
NDA |
NetStream Data Analyzer |
NDE |
NetStream Data Exporter |
NDP |
NET |
Network Entity Title |
NetBIOS |
Network Basic Input/Output System |
NETCONF |
Network Configuration Protocol |
NFAS |
non–FAS |
NHLFE |
Next Hop Label Forwarding Entry |
NI |
National ISDN |
NIB |
Nexthop Information Base |
NIC |
Network Interface Card |
NII |
Network International Identifier |
NIST |
National Institute of Standard and Technology |
NIT |
Not Initial Terminal |
NLB |
Network Load Balancing |
NLBS |
Network Load Balancing Services |
NLPID |
Network Layer Protocol Identifier |
NLRI |
Network Layer Reachability Information |
NM |
Network Management |
NMFAS |
Non-Multiframe FAS |
NMS |
Network Management System |
NMS |
Network Management Server |
NMS |
Network Management Station |
NNI |
Network-to-Network Interface |
NPDU |
Network Protocol Data Unit |
NPE |
Network Provider Edge |
NPV |
N_Port Virtualization |
NQA |
Network Quality Analyzer |
nrt-VBR |
non-real-time Variable Bit Rate |
NRZ |
NonReturn to zero |
NRZI |
NonReturn to Zero Inverted |
NS |
Neighbor Solicitation |
NSAP |
Network Service Access Point |
NSC |
NetStream Collector |
N-SEL |
NSAP Selector |
NSF |
Non-Standard Facilities |
NSR |
Nonstop Routing |
NSSA |
Not-So-Stubby Area |
NTDP |
Neighbor Topology Discover Protocol |
NTE |
Named Telephone Event |
NTL |
Need to Know |
NTP |
Network Time Protocol |
NTT |
Nippon Telegraph and Telephone Corporation |
O Flag |
Other Stateful Configuration Flag |
OAA |
Open Application Architecture |
OAM CC |
OAM Continuity Check |
OAMPDU |
Operation, Administration and Maintenance Protocol Data Unit |
OAMPDU |
OAM Protocol Data Units |
OAP |
Open Application Platform |
OC |
Optical Carrier |
OC |
Ordinary Clock |
ODF |
Optical Distribution Frame |
OID |
Object Identifier |
OOB |
Out-of-Band |
OOF |
Out of Frame |
ORF |
Outbound Route Filtering |
OSI |
Open System Interconnection |
OSPF |
Open Shortest Path First |
OU |
Organization Unit |
OUI |
Organizationally Unique Identifier |
P device |
Provider Device |
P2MP |
Point-to-MultiPoint |
P2P |
PW to PW |
P2P |
Peer-to-Peer |
P2P |
Point-to-Point |
P2PTC |
Peer-to-Peer Transparent Clock |
PAD |
Packet Assembly/Disassembly |
PADT |
PPPoE Active Discovery Terminate |
PAGP |
Port Aggregation Protocol |
PAM |
Pulse Amplitude Modulation |
PAM |
Port to Application Map |
PAP |
Password Authentication Protocol |
PAT |
Port Address Translation |
PBAR |
Port Based Application Recognition |
PBB |
Provider Backbone Bridge |
PBBN |
Provider Backbone Bridge Network |
PBN |
Provider Bridge Network |
PBO |
Power Backoff |
PBR |
Policy-based Routing |
PBX |
Private Branch Exchange |
PCB |
Protocol Control Block |
PCM |
PCR |
Peak Cell Rate |
PD |
Prefix Delegation |
PD |
Powered Device |
PDH |
Plesiochronous Digital Hierarchy |
PDP |
Policy Decision Point |
PDU |
PE |
Provider Edge |
PE-agg |
PE Aggregation |
PEAP |
Protected EAP |
PEAP |
Protected Extensible Authentication Protocol |
PEAP-GTC |
Protected Extensible Authentication Protocol-Microsoft Generic Token Card |
PEAP-MSCHAPv2 |
Protected Extensible Authentication Protocol-Microsoft Challenge Handshake Authentication Protocol v2 |
PEM |
Privacy Enhanced Mail |
PEM |
Power Entry Module |
PEP |
Policy Enforcement Point |
PFC |
Priority-based Flow Control |
PFC |
Protocol-Field-Compression |
PFS |
Perfect Forward Secrecy |
PHB |
Per-hop Behavior |
PHP |
Penultimate Hop Popping |
PI |
Power Interface |
PIC |
Prefix Independent Convergence |
PIM |
PIM-DM |
Protocol Independent Multicast-Dense Mode |
PIM-SM |
Protocol Independent Multicast-Sparse Mode |
PIM-SSM |
Protocol Independent Multicast Source-Specific Multicast |
PIN |
Personal Identification Number |
PIR |
Peak Information Rate |
PKCS |
Public Key Cryptography Standards |
PKI |
Public Key Infrastructure |
PLAR |
Private Line Auto Ring-down |
PLMN |
Public Land Mobile Network |
PLR |
Point of Local Repair |
PMK |
Pairwise Master Key |
PMTU |
Path MTU |
PN |
Packet Number |
PoE |
Power over Ethernet |
POH |
Path Overhead |
POP3 |
Post Office Protocol, version 3 |
POS |
Point of Sale |
POST |
Power-On Self-Test |
POTS |
Plain Old Telephone Service |
PPP |
Point-to-Point Protocol |
PPPoA |
PPP Over ATM |
PPPoE |
Point-to-Point Protocol over Ethernet |
PPPoEoA |
PPPoE Over ATM |
PPPoFR |
PPR |
Periodical Performance Report |
PPTP |
Point-to-Point Tunneling Protocol |
PPVID |
Port and Protocol VLAN ID |
PQ |
Priority Queuing |
PQL |
Priority Queue List |
PRBS |
Pseudo Random Bit Sequence |
PRF |
Pseudo-Random Function |
PRI |
Primary Rate Interface |
PRL |
Preferred Roaming List |
PS |
Protection Switching |
PSB |
Path State Block |
PSC |
Protection State Coordination |
PSD |
Power Spectral Density |
PSE |
Power Sourcing Equipment |
PSK |
Pre-Shared Key |
PSN |
Packet Switched Network |
PSNP |
Partial SNP |
PSNP |
Partial Sequence Number PDU |
PSST |
Principal Switch Selection Timer |
PSTN |
Public Switched Telephone Network |
PTK |
Pairwise Transient Key |
PTP |
Precision Time Protocol |
PTY |
Pseudo-Terminals |
PUK |
PIN Unlocking Key |
PVC |
Permanent Virtual Circuit |
PVC PQ |
PVC Priority Queuing |
PVID |
Port Vlan ID |
PVP |
Permanent Virtual Path |
PVST |
Per-VLAN Spanning Tree |
PW |
Pseudowire |
PW-ACH |
PW Associated Channel Header |
PWE3 |
Pseudo Wire Emulation Edge-to-Edge |
PXE |
Preboot eXecution Environment |
QoS |
QPPB |
QoS Policy Propagation Through the Border Gateway Protocol |
RA |
Router Alert |
RA |
Registration Authority |
RA |
Router Advertisement |
RADIUS |
Remote Authentication Dial-In User Service |
RAGG |
Route-Aggregation |
RAI |
Remote Alarm Indication |
RALM |
RADIUS Authenticated Login Using MAC-address |
RAS |
Registration, Admission, and Status |
RB |
Routing Bridge |
RBAC |
Role Based Access Control |
RCA |
Release Change Authorization |
RD |
Route Distinguisher |
RD |
Routing Domain |
RDI |
Remote Defect Indication |
RDM |
Russian Dolls Model |
Recommendation |
Enhanced Transmission Selection Recommendation Configuration |
RED |
Random Early Detection |
RF Ping |
Radio Frequency Ping |
RFID |
Radio Frequency Identification |
RIB |
Routing Information Base |
RIB |
Route Information Base |
RIP |
Routing Information Protocol |
RIP-2 |
Routing Information Protocol version 2 |
RIPng |
RIP next generation |
RLSN |
Remote Link Status Notification |
RMON |
Remote Network Monitoring |
ROA |
Recognized Operating Agency |
RP |
Rendezvous Point |
RPA |
Rendezvous Point Address |
RPF |
Reverse Path Forwarding |
RPL |
Rendezvous Point Link |
RPR |
Resilient Packet Ring |
RP-Set |
Rendezvous Point Set |
RPT |
Rendezvous Point Tree |
RR |
Router Renumber |
RR |
Receiver Ready |
RR |
Route Reflector |
RR |
Reflective Relay |
RRI |
Reverse Route Injection |
RRPP |
Rapid Ring Protection Protocol |
RRPPDU |
Rapid Ring Protection Protocol Data Unit |
RS |
Router Solicitation |
RSB |
Reservation State Block |
RS-DCC |
Resource-Shared DCC |
RSH |
Remote Shell |
RSN |
Robust Security Network |
RSNA |
Robust Security Network Association |
RSOH |
Regenerator Section Overhead |
RSSI |
Received Signal Strength Indication |
RSTP |
Rapid Spanning Tree Protocol |
RSVP |
Resource Reservation Protocol |
RTC |
Remote Terminal Connection |
RTCP |
Real-time Transport Control Protocol |
RTE |
Route Table Entry |
RTM |
Real-Time Event Manager |
RTP |
Real-time Transport Protocol |
RTPQ |
Real-time Transport Protocol Priority Queuing |
RTS |
Request to Send |
RTSP |
Real Time Streaming Protocol |
RTT |
Round Trip Time |
RTT |
Round-trip Time |
rt-VBR |
Real-time Variable Bit Rate |
RU |
Rack Unit |
S/MIME |
Secure/Multipurpose Internet Mail Extensions |
SA |
Suppress-Advertisement |
SA |
Source Active |
SA |
Security Association |
SABM |
Set Asynchronous Balanced Mode |
SAFI |
Subsequent Address Family Identifier |
SAII |
Source Attachment Individual Identifier |
SAN |
Storage Area Networks |
SAP |
Service Advertising Protocol |
SAR-PDU |
Segmentation and Reassembly Protocol Data Unit |
SATOP |
Structure-Agnostic TDM over Packet |
SAVI |
Source Address Validation |
SB |
Service Bridge |
SBM |
Subnetwork Bandwidth Management |
SCCP |
Skinny Client Control Protocol |
SCEP |
Simple Certificate Enrollment Protocol |
SCFF |
Single Choke Fairness Frame |
SCR |
Sustainable Cell Rate |
SD |
Signal Degrade |
SDH |
Synchronous Digital Hierarchy |
SDLC |
Synchronous Data Link Control |
SDMF |
Single Data Message Format |
SDP |
Session Description Protocol |
SDSL |
Symmetric Digital Subscriber Line |
SDU |
Service Data Unit |
SE |
Shared-Explicit |
SEF |
Severely Errored Frame |
SF |
Super Frame |
SF |
Signal Fail |
SFC |
Stage Fabric Configuration Update |
sFlow |
Sampled Flow |
SFM |
Source-Filtered Multicast |
SFP |
Small Form-factor Pluggable |
SFP+ |
SFP Plus |
SFTP |
Secure FTP |
SHA |
Secure Hash Algorithm |
SIP |
Session Initiation Protocol |
SIPS |
SIP secure |
SIP-T |
SIP for Telephones |
SLA |
Service Level Agreement |
SLAAC |
Stateless Address Autoconfiguration |
SLC |
Service Logic Control |
SLIC |
Subscriber Line Interface Circuit |
SLIP |
Serial Line Internet Protocol |
SMB |
Standby Main Board |
SMTP |
Simple Mail Transfer Protocol |
SN |
Serial Number |
SNA |
System Network Architecture |
SNAP |
Subnetwork Access Protocol |
SNAT |
Source Network Address Translation |
SNMP |
Simple Network Management Protocol |
SNP |
Sequence Number PDUs |
SNPA |
Subnetwork Point of Attachment |
SNR |
Signal-to-Noise Ratio |
SNTP |
Simple NTP |
SNTP |
Simple Network Transfer Protocol |
SOH |
Section Overhead |
SONET |
Synchronous Optical Network |
SoO |
Site of Origin |
SP |
Service Provider |
SP |
Strict Priority |
SPBM |
Shortest Path Bridging MAC Mode |
SPCS |
Stored Program Control Switching System |
SPE |
Superstratum PE or Service Provider-end PE |
SPF |
SPI |
Security Parameter Index |
SPID |
Service Profile Identification |
SPT |
Shortest Path Tree |
SQL |
Structured Query Language |
SR/TLB |
Source-route Translational Bridging |
SRB |
Source-Route Bridging |
Srefresh |
Summary Refresh |
SRPU |
Switching and Routing Processing Unit |
srTCM |
single rate TCM |
SRTP |
Secure Real-time Transport Protocol |
SSA |
SIP Stack Adapt |
SSH |
Secure Shell |
SSID |
Service Set Identifier |
SSL |
Secure Sockets Layer |
SSM |
SSM |
Synchronization Status Marker |
SSP |
Switch-to-Switch Protocol |
ST |
Shared Tree |
STAC-LZS |
STAC Lempel-Ziv Standard |
Stelnet |
Secure Telnet |
STP |
STR |
Switch Trace Route |
SVC |
Switched Virtual Circuit |
SVC |
Static Virtual Circuit |
SVP |
SpectraLink Voice Priority |
Syslog |
System Log |
TA |
Terminal Adapter |
TACACS |
TACL |
Temporary Access Control List |
TAI |
International Atomic Time |
TAII |
Target Attachment Individual Identifier |
TC |
Topology Checksum |
TC |
Transparent Clock |
TC |
Traffic Class |
TCI |
Tag Control Information |
Tcl |
Tool Command Language |
TCN BPDU |
Topology Change Notification BPDU |
TDM |
Time Division Multiplexing |
TE |
TEC |
Thermoelectric Cooler |
TEDB |
TE DataBase |
TFC |
Traffic Flow Confidentiality |
TFTP |
Trivial File Transfer Protocol |
TKIP |
Temporal Key Integrity Protocol |
TLP |
Transport Layer Protocol |
TLS |
TLS |
Transparent LAN Service |
TLV |
Type/Length/Value |
ToS |
Type of Service |
TP |
Topology Protection |
TP |
Traffic Policing |
TPC |
Transmit Power Control |
TPDU |
Transport Protocol Data Unit |
TPID |
Tag Protocol Identifier |
TPMR |
Two-Port MAC Relay |
TRILL |
TRansparent Interconnection of Lots of Links |
TRIP |
Triggered RIP |
trTCM |
two-rate TCM |
TS |
Time Slot |
TS |
Traffic Shaping |
TST |
Test |
TTL |
Time to Live |
TTLS |
Tunneled Transport Layer Security |
TTY |
True Type Terminal |
TU |
Time Unit |
TU |
Tributary Unit |
TUG |
Tributary Unit Group |
TXOPLimit |
Transmission Opportunity Limit |
U/L |
Universal/Local |
UA |
User Agent |
UA |
Unnumbered Acknowledge |
UAC |
User Agent Client |
U-APSD |
Unscheduled Automatic Power-Save Delivery |
UAS |
User Agent Server |
UBR |
Unspecified Bit Rate |
UDLD |
Uni-directional Link Direction |
UDP |
User Datagram Protocol |
UFC |
Update Fabric Configuration |
UIM |
User Identity Module |
UNI |
User Network Interface |
UPE |
Underlayer PE or User-end PE |
UPE |
User facing-Provider Edge |
UPE |
Underlayer PE |
URL |
Uniform Resource Locator |
uRPF |
Unicast Reverse Path Forwarding |
USB |
Universal Serial Bus |
USK |
Unicast Session Key |
USM |
User-Based Security Model |
UTC |
Coordinated Universal Time |
UTM |
Unified Threat Management |
VA |
Virtual Access |
VAD |
Voice Activity Detection |
VAM |
VPN Address Management |
VBD |
Voice Band Data |
VC |
Virtual Container |
VC |
Virtual Circuit |
VCC |
Virtual Circuit Connection |
VCCV |
Virtual Circuit Connectivity Verification |
VCI |
Virtual Channel Identifier |
VCN |
Virtual Circuit Number |
VCPM |
Voice Co-processing Module |
VCT |
Virtual Cable Test |
VCX |
Voice Core Exchange |
VD |
Virtual Device |
VDP |
VSI Discovery and Configuration Protocol |
VDSL |
Very High-rate Digital Subscriber Line |
VE |
Virtual Ethernet |
VE-Bridge |
Virtual Ethernet Bridge |
VF Owner |
Virtual Forwarder Owner |
VFC |
Virtual Fiber Channel |
VJ TCP/IP |
V. Jacobson Compressing TCP/IP |
VLAN |
Virtual Local Area Network |
VMM |
Virtual Machine Management |
VN |
Version Number |
VNC |
Virtual Network Computing |
VoD |
Video on Demand |
VoFR |
Voice Over Frame Relay |
VoIP |
Voice over IP |
VP |
Virtual Path |
VPC |
Virtual Path Connection |
VPDN |
Virtual Private Dial-up Network |
VPI |
Virtual Path Identifier |
VPLS |
Virtual Private LAN Service |
VPM |
Voice Processing Module |
VPN |
VRF |
Virtual Routing and Forwarding |
VRRP |
Virtual Router Redundancy Protocol |
VSAN |
Virtual Storage Area Network |
VSI |
Virtual Station Interface |
VSI |
Virtual Switch Instance |
VSIP |
Virtual Service IP |
VT |
Virtual Template |
VTP |
VLAN Trunking Protocol |
VTY |
Virtual Type Terminal |
WAI |
WLAN Authentication Infrastructure |
WAN |
Wide Area Network |
WAPI |
WLAN Authentication and Privacy Infrastructure |
WDS |
Wireless Distribution System |
WEP |
Wired Equivalent Privacy |
WFQ |
WIDS |
Wireless Intrusion Detection System |
WiNet |
Wisdom Network |
WINS |
Windows Internet Naming Service |
WIPS |
Wireless Intrusion Prevention System |
WLAN |
Wireless Local Area Network |
WLAN RRM |
WLAN Radio Resource Management |
WMM |
Wi-Fi Multimedia |
WPA |
Wi-Fi Protected Access |
WPAD |
Web Proxy Auto-Discovery |
WPI |
WLAN Privacy Infrastructure |
WRED |
Weighted Random Early Detection |
WRR |
Weighted Round Robin |
WWN |
World Wide Name |
X2T |
X.25 to TCP Switch |
XFP |
10-Gigabit Small Form-factor Pluggable |
XML |
Extensible Markup Language |
XOT |
X.25 Over TCP |
XSD |
XML Schema Document |
XSD |
XML Schema Definition |
ZBR |
Zone Border Router |
